LEGO rebrick - BE A LEGO CREATOR
Startat av Anders67, 09 Augusti 2017 kl. 22:56
Från LEGO Ambassador LAN forum
https://www.lego.com/en-us/rebrick/contest-page/contests/be-a-lego-creator
CitatCONTEST DESCRIPTION
With 31069 Modular Family Villa, 31068 Modular Modern Home, or 31067 Modular Poolside Holiday, LEGO Creator 3in1 has branched out to a new modular system, with a focus on mixing and combing the different parts, or modules of the set. What would you add to these sets? Maybe an additional room, dock, or even another story to one of these building! Show us by building a module to add to a sets and you could win a collection of six LEGO Creator sets.
In this contest, we define a module as being an 8x8 or 8x16 stud structure, which can be placed in different combinations and attached to other modules by 1x4 plates with 2 studs connection. Modules can be places on top of each other, side by side and underneath.
You can build an additional room, or an outdoor space with no frame - It's up to you how you will add it into one of these three sets! Be a LEGO Creator and show us what you can create!
Before you start please check out the entry guidelines and how to enter in the RULES.
Entry Deadline
Submit your entry no later than September 15th 2017 at 10:00AM EST.
If you're not sure what time zone you're in here's a time zone converter.
Judging
A panel of judges from the LEGO Creator team will one grand prize winner and two runner up winners. They will judge entries upon:
- Overall coolness and originality: 25%
- Most inspired details on the module: 25%
- Attention to contest theme: 25%
- Best use of LEGO elements: 25%
How to enter
- Build a module which measures 8x8 or 8x16 studs for 31069 Modular Family Villa, 31068 Modular Modern Home, and/or 31069 Modular Poolside Holiday
- Take up to five photos of your creation and submit them to the contest Make sure to show off all angles of your creation
- Use the description field to tell us which set your module belongs to – then hit "submit"
- When you receive a "Success!" pop-up notification after clicking "submit" on the entry submission page, your entry has successfully been submitted. Our moderation team will review it within 1-3 working days to make sure it fits all the contest rules
Orkar inte läsa engelska, kan man få en snabb summering på svenska?
Pekblom
Citat från: andreaseldh skrivet 11 Augusti 2017 kl. 00:24
KONTROLL BESKRIVNING
Med 31069 Modular Family Villa, 31068 Modular Modern Home eller 31067 Modular Poolside Holiday har LEGO Creator 3in1 förgrenat sig till ett nytt modulärt system med fokus på blandning och kamning av de olika delarna eller modulerna i uppsättningen. Vad skulle du lägga till i dessa uppsättningar? Kanske ett extra rum, docka eller till och med en annan historia till en av dessa byggnader! Visa oss genom att bygga en modul för att lägga till en uppsättning och du kan vinna en samling av sex LEGO Creator-uppsättningar.
I denna tävling definierar vi en modul som en 8x8 eller 8x16 studstruktur, som kan placeras i olika kombinationer och kopplas till andra moduler med 1x4-plattor med 2 kontakter. Moduler kan placeras ovanpå varandra, sida vid sida och underifrån.
Du kan bygga ett extra rum eller ett utomhusutrymme utan ram - Det är upp till dig hur du lägger till det i en av dessa tre uppsättningar! Var en LEGO Creator och visa oss vad du kan skapa!
Innan du börjar, kolla in riktlinjerna för inmatning och hur du skriver in i REGLERNA.
Inlämningsfrist
Skicka in din inlämning senast den 15 september 2017 klockan 10:00 EST.
Om du inte är säker på vilken tidszon du är här är en tidszonomvandlare.
Bedömning
En panel av domare från LEGO Creator-laget kommer en storprisvinnare och två vinnare till vinnare. De kommer att döma in på:
- Total kyla och originalitet: 25%
- De flesta inspirerade detaljerna på modulen: 25%
- Uppmärksamhet på tävlingstema: 25%
- Bästa användningen av LEGO-element: 25%
Hur man går in
- Bygg en modul som mäter 8x8 eller 8x16 studs för 31069 Modular Family Villa, 31068 Modular Modern Home, och / eller 31069 Modular Poolside Holiday
- Ta upp till fem bilder av din skapelse och skicka dem till tävlingen Se till att visa upp alla vinklar av din skapelse
- Använd beskrivningsfältet för att berätta vilken inställning din modul tillhör - klicka sedan på "Skicka"
- När du får popup-meddelandet "Framgång!" Efter att du har klickat på "Skicka" på sidan för inlämning av inlägg har din inlägg skickats. Vårt modereringslag granskar det inom 1-3 arbetsdagar för att se till att det passar alla tävlingsregler
Tack Google translate för att du upptäckte att det stod combing istället för combining i originaltexten.
